Javascript error when updating UE3 script with UE4
Thread begun 6/28/2010 6:39 am by pascal267973 | Last modified 6/29/2010 3:52 pm by Jimmy Wu | 2414 views | 4 replies |
pascal267973
Whenever I try to update/upgrade a existing script created with UE3 using UE4, I get the following error:
While executing timer in WA Universal Email.htm, the following JavaScript error occured:
At line 2765 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Commands\WA Universal Email.js": document.Body.document.prevtab2 has no properties
Can you help?
Pascal
Jimmy Wu
Follow the steps outlined in the common installation issues to get to the configuration directory:
After that, go to the \Configuration\Commands\ directory and open the WA Universal Email.js file. Go to line 2765, which should look like this:
document.Body.document.prevtab2.style="border-top-width:2; border-left-width:2; border-right-width:2; vertical-align:top; border-top:solid; border-top-color:#D8CDAC; border-left:solid; border-left-color:#D8CDAC; border-right:solid; border-right-color:#D8CDAC; padding-left:3; padding-right:3; padding-top:3; padding-bottom:3;";
Add a line right before it that looks like this:
if(document.Body.document.prevtab2)
pascal267973
Thanks.
I am assuming that I need to use curly brackets, but am not sure where the closing one should be placed. Do you mean that it should be like:
if(document.Body.document.prevtab2) {
Or should the closing bracket be placed further down the script?
pascal267973
It only seems to work if I do it like that:
document.Body.document.prevlink2.style="font-weight:810; color:#000000; text-decoration:none";
document.Body.document.prevlink1.style="color:#CCCCCC; text-decoration:none";
startPrevTab = 2;
Is that correct or will it have an impact on something else?
Jimmy Wu
Yes, that should be the correct way to add the check. If you run into any additional errors, feel free to open a new thread.
