ecart shipping
Thread begun 6/27/2010 8:46 pm by watercolor346374 | Last modified 6/30/2010 10:23 am by watercolor346374 | 4755 views | 12 replies |
watercolor346374
ecart shipping
I set up my shipping rules for the US, which are rather complicated. They are not working. I am sending the script. I have four shipping rules for the US. I used the session variable:
eCartCheckoutForm_shipping_country. Also want to set up for next day in US with a flat rate.
The out of US rules will be similar.
Thank you
you also need to send the winkee_PHP.php so I can see what the shipping rule definitions are.
Also, add the following code:
<pre><?php
if(!session_id()) session_start();
var_dump($_SESSION);
?></pre>
after the <body> tag and report the results.
watercolor346374
Here are the results:
array(29) {
["cust"]=>
string(2) "55"
["total"]=>
float(20)
["shipcost"]=>
string(1) "5"
["tax"]=>
string(1) "0"
["track_num"]=>
string(0) ""
["winkee_admin"]=>
string(6) "kkbird"
["food_mart_admin"]=>
string(5) "admin"
["levelid"]=>
string(1) "1"
["shop"]=>
array(3) {
[0]=>
string(2) "32"
[1]=>
string(2) "17"
[2]=>
string(2) "15"
["pass_phrase"]=>
string(40) "3de9647ccdb3564c0083a35f26e3b3d433cb295d"
["vercode"]=>
int(83976)
["cart"]=>
array(0) {
["megan_admin"]=>
string(6) "kkbird"
["megan_isaacs_Items"]=>
string(157) "223|WAECART|2222|WAECART|bracelets|WAECART|0|WAECART|2|WAECART|50|WAECART|om12iii.jpg|WAECART||WAECART||WAECART|95|WAECART|0|WAECART|100|WAECART|2 2222 (223)"
["WAEC_ContinueRedirect"]=>
string(28) "/winkee/detail.php?prodid=41"
["winkee_Items"]=>
string(399) "46|WAECART||WAECART|Spy Tape|WAECART|0|WAECART|1|WAECART|5|WAECART|parsley.jpg20100604224337|WAECART||WAECART||WAECART|0|WAECART|12121212|WAECART||WAECART||WAECART|0|WAECART|5|WAECART|1 (46)&#65533;41|WAECART||WAECART|Black Rouched|WAECART|0|WAECART|1|WAECART|22|WAECART|chefhat.jpg20100601221932|WAECART|Long Tab|WAECART||WAECART|19|WAECART|97897979|WAECART||WAECART||WAECART|0|WAECART|22|WAECART|1 (41)"
["lolos_boutique_Items"]=>
string(457) "18|WAECART|Treasure|WAECART|Treasure Rock Angle Print Tank Ruffle Bottom with Gold Stones |WAECART|5|WAECART|1|WAECART|48.8|WAECART|small|WAECART||WAECART|0|WAECART|1|WAECART|0|WAECART|0|WAECART|0|WAECART|5|WAECART|48.8|WAECART|1 Treasure (18)&#65533;78|WAECART|Fillmore|WAECART|Fillmore, White Duck Vote Tee 2008|WAECART|5|WAECART|1|WAECART|26|WAECART|small|WAECART||WAECART|0|WAECART|1|WAECART|0|WAECART|0|WAECART|0|WAECART|5|WAECART|26|WAECART|1 Fillmore (78)"
["eCartCheckoutForm_state_province"]=>
string(2) "AL"
["eCartCheckoutForm_country"]=>
string(2) "US"
["eCartCheckoutForm_shipping_state_province"]=>
string(2) "AL"
["eCartCheckoutForm_shipping_country"]=>
string(2) "US"
["date"]=>
string(19) "2010-06-28 13:36:29"
["insert_order_status"]=>
string(7) "pending"
["eCartCheckoutForm_counties"]=>
string(5) "0.065"
["winkee_OrderID"]=>
int(124)
["megan_isaacs_OrderID"]=>
int(74)
["countyid"]=>
string(0) ""
["counties"]=>
string(5) "0.075"
["backorder"]=>
string(0) ""
array(29) {
["cust"]=>
string(2) "55"
["total"]=>
float(20)
["shipcost"]=>
string(1) "5"
["tax"]=>
string(1) "0"
["track_num"]=>
string(0) ""
["winkee_admin"]=>
string(6) "kkbird"
string(5) "admin"
["levelid"]=>
string(1) "1"
["shop"]=>
array(3) {
[0]=>
string(2) "32"
[1]=>
string(2) "17"
[2]=>
string(2) "15"
["pass_phrase"]=>
["vercode"]=>
int(83976)
["cart"]=>
array(0) {
["megan_admin"]=>
string(6) "kkbird"
["winkee_Items"]=>
string(2) "AL"
string(2) "US"
string(2) "AL"
string(2) "US"
["date"]=>
string(19) "2010-06-28 13:41:31"
string(7) "pending"
string(5) "0.065"
int(124)
int(74)
["countyid"]=>
string(0) ""
["counties"]=>
string(5) "0.075"
["backorder"]=>
string(0) ""
Thank you,
K
So, the countyid session is not getting a value:
["countyid"]=>
string(0) ""
["counties"]=>
string(5) "0.075"
perhaps you should be using the counties session variable
the problem is the triggers you are using.
In each of the rules you are using a trigger for the total being equal to a value.
but then another trigger for less than or equal to a different value.
I think you should be using Greater than or Equal ">=" for the first trigger instead of Equal "="
watercolor346374
shipping still not showing
Hi Jason,
I changed the = to >= and the shipping still does not show up.
Thank you,
K
watercolor346374
Hi Jason,
I went back into the ecart object...none of my changes took, so I redid it and tested again, they took and the shipping is correct. I do notice that even thought shipping label does not show in my cart, if I get to the confirm, and the shipping shows, then I go back to change my cart and add more, the shipping is being added into the cart total...how do I prevent the shipping from showing in the cart...when the cart is fresh, it does not show.
well, once the shipping country is set in a session, the shipping will always be appied.
you could add the following code to the cart page to unset the shipping:
if(isset(
$_SESSION["eCartCheckoutForm_shipping_country"])) unset($_SESSION["eCartCheckoutForm_shipping_country"]);
watercolor346374
Placed it at different parts of the page and still the total reflects the shipping
watercolor346374
shipping not unsetting
Hi Jason,
Now I see the problem...If I shop and then at check out add the info and input US, I get to my confirm page. Then I decide to modify the info and click the button go back to the checkout page then change the country, go to the confirm page, the shipping reflected is the shipcost for the us and out of us combined. How can the shipping be unset in the confirm page when a customer wants to change their info? They will have to change it all since the page will have validations.
