eCart not binding orders & order details
Thread begun 6/27/2010 6:52 am by mora398588 | Last modified 7/11/2010 1:14 pm by alizamp405574 | 3111 views | 6 replies |
mora398588
I recently noticed that my confirm.php page is not posting data to my products database. I have attempted to go into the server behaviors to update the bindings, but I either I have made a serious error or the trigger is not doing the trick, I am uncertain.
Could you take a look at my file (see attachment) and advise on any errors you may find.
Thank you.
since you are using a remote checkout out, your checkout form posts to the gateway server:
<form name="checkout_AN_Cmp_Hid" action="https://secure.authorize.net/gateway/transact.dll" method="post">
in this case, you must store the order information when the checkout posts to the confirm page. you cannot store the order information when the confirm page posts.
mora398588
So, do you recommend that I copy and paste or move the code posting the orders and order details data to the checkout.php page in lieu of the confirm page?
No, use the Any Form Post trigger instead of triggering of the confirm button being pressed.
mora398588
Another Problem
Jason, I followed your instructions and, at first, it began to work just fine; data was being posted to the database.
Now that things were looking up, I proceeded to update my customer order history page to make sure that it was pulling data successfully. At first, it was not showing any order history (after submitting a couple of test purchases). So I looked up your solution recipe for creating a customer order history page and noticed that the confirm.php page was not posting the UserID to the database for the history page to reference. So, I modified the code and included the UserID session variable. After saving all my pages, I performed a test run.
Well, I noticed that the confirm.php page, once again, was not posting data anymore. At first I thought that maybe the database was not recognizing a particular field in the confirm page...that did not seem to be the problem (from what I observed). Interestingly enough, it was populating / updating the UserID's for all previous orders that I posted just awhile back. I ran a couple of more tests, but the confirm page just was not posting. I am at a loss once again.
I am uncertain as to whether the db is the problem (the OrderUserID is an integer(11) no null and no default...the db has the OrderUserID as an INDEX connected to the file OrderUserID). The confirm page is configured to post using any form post.
I am in need of your assistance once again. Please reference another copy of my file as it is now. Thank you.
as long as the checkout page is posting to the confirm page, this will be adding the information to the database.
Have you checked the database directly for the order? or are you just using the order History page.
there is no problem that I can see in the code that would cause the order not to be stored in the database. check the database directly to make sure.
alizamp405574
follow up to Mora's msg
I have the same problem and would like to know if you were able to solve the database problem.
My db settings/trigger is identical to yours and yet it is not working, not collecting any data and don't know what to do anymore, everything works perfectly except db.
By inserting the trigger it has caused another problem as well, the customer information is not passed thru anymore to Authorize Net, the $/tax/shipping all is passed on to authorize net but not the info entered by the customer.
So now I'm dealing with 2 new problems and feeling totally lost.
