Spam User registering on Registration page
Thread begun 6/27/2010 2:49 am by info399547 | Last modified 4/22/2014 8:50 am by Jason Byrnes | 2261 views | 3 replies |
info399547
I have created a registration page using DataAssist 2.0.7.
In the registration page i have 2 emails generated by UE 4, one for the user and one for me.
I have noticed that there are tons of spam users created in the database, and no email is generated either to the user or to me.
How is this happening and how can i avoid it?
Below is the section of the code i'm using in the Registration.php page
<?php require_once('../Connections/scipt.php'); ?>
<?php require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
<?php require_once("../webassist/email/mail_php.php"); ?>
<?php require_once("../webassist/email/mailformatting_php.php"); ?>
$today = date("Y-m-d");
if (!isset($_SESSION)) {
session_start();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="registration_error.php";
$loginUsername = $_POST['username'];
$LoginRS__query = sprintf("SELECT username FROM registration WHERE username=%s", GetSQLValueString($loginUsername, "text"));
mysql_select_db($database_scipt, $scipt);
$LoginRS=mysql_query($LoginRS__query, $scipt) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "registration")) {
$insertSQL = sprintf("INSERT INTO registration (name, surname, email, additional_email, `position`, department, institute, city, country, username, date_registered) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString(ucfirst($_POST['firstname']), "text"),
GetSQLValueString(ucfirst($_POST['surname']), "text"),
GetSQLValueString(strtolower($_POST['email']), "text"),
GetSQLValueString(strtolower($_POST['add_email']), "text"),
GetSQLValueString(ucwords($_POST['position']), "text"),
GetSQLValueString(ucwords($_POST['department']), "text"),
GetSQLValueString(ucwords($_POST['institute']), "text"),
GetSQLValueString(ucwords($_POST['city']), "text"),
GetSQLValueString($_POST['country'], "text"),
GetSQLValueString(strtolower($_POST['username']), "text"),
GetSQLValueString($_POST['date_registered'], "date"));
$Result1 = mysql_query($insertSQL, $scipt) or die(mysql_error());
$_SESSION['registrationID'] = mysql_insert_id();
if (!isset($_SESSION))session_start();
if ((isset($_POST["Register_x"]))) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_registration_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("../webassist/email/waue_registration_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
set_time_limit(0);
$EmailRef = "waue_registration_2";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "thanks.php";
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
$RecipArray[$CurIndex ][] = "adminSCIPT@med.usyd.edu.au";
$RecipArray[$CurIndex ][] = "info@andreabuldorini.com.au";
$CurIndex = 0;
} else {
PS a part of the final code is missing due to character limitations!
Cheers
Andrea
To help prevent spam registrations, use server validations from CSS Form Builder to prevent bad values from being added to the registrations fields such as email or first name and last name.
You could also use CSS form builder to rebuild the registration form and add a captcha field to force human verification.
If you recreate the registration form using CSS form builder, you probably need to recreate insert record behavior and the emails since the form element names will probably be changed
Lummo
A 'trick' that I have found very effective at detecting spambots filling in forms without having to put the user to the pain of completing a Captcha is to add a field to the form and then set it display: none in the CSS. Spambots will find the field and complete it. Human users don't see the field so must leave it empty. The form handler can take a look to see if there is anything in the field and dump the submission if there is. I call my field "firstName" to give the spambots a bit of a hint in case they are parsing the field names in any way.
I've been running this code on one of my sites for over a year now. I monitored the outcomes for six months and had no false positives or negatives so I now just dump the submission and present the normal 'Thank You' page so that I'm not giving any othe rinformation away.
Hope that helps.
This technique is called Honey Pots.
You can implement this using Server Validation included with Data Bridge.
In the server validation settings, select the hidden element as the server variable and use the Regular Expression validation type, set the Regular Expression to:
/^$/i
which allows only an empty string.
