on submission of the form, thankyou.php doesn't come up
Thread begun 6/26/2010 1:48 am by nick354316 | Last modified 6/28/2010 11:34 am by Jimmy Wu | 3309 views | 5 replies |
nick354316
The contact form works as it should: Click on submit, and the email is sent. However, once the submit button is pressed, rather than the thankyou.php coming up to verify that the form email was sent, the contact form returns, ready to be filled out again.
The user has no confirmation that the form information was sent.
I am working in Dreamweaver CS3, and do have Universal Email version 4, which may not be pertinent, but just in case you need to know.
neilo
Hi Nick,
The thankyou.php page is specified in this bit of code (just before the DOCTYPE declaration) usually at or near line 34:
//Send Mail All Entries
if ("index.php"!="") {
header("Location: thankyou.php");
If you haven't changed that, then it may be that another problem is preventing the redirect.
Could you zip the contactus.php page and upload it here? It might help also if you could provide a link to the page.
nick354316
Hi neilo - Thank you for your response. I did a search on the code of the page and didn't see any mention of 'thankyou.php.' I have attached a copy of the contact page. Any help you can give will be welcomed.
Jimmy Wu
That doesn't look like the default contactus.php file that in included in the contact form solution pack. What changes did you make to the page before this stage?
It looks like you will want to change this line:
$GoToPage = "";
to look like this:
$GoToPage = "thankyou.php";
nick354316
thank you message not displayed once contact form is submitted.
Hi Jimmy - Thanks for the help. It's working now.
It didn't work when I entered just the 'thankyou.php.' I received a 'page not found' error. As I recently went live with the site, I entered the full http path to the file, and it worked.
As far as changes, all I really did was apply my own template to the form. I must have somehow inadvertently deleted the one line of code. Regardless, it is working now.
All I need now to finish the site is the resolution to my other two support items.
Thank you for your help with the thank you, Jimmy! My frustration with that issue is officially over.
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
