Problems with the search
Thread begun 6/25/2010 9:34 am by tyler815351411 | Last modified 6/25/2010 11:40 am by Jimmy Wu | 1158 views | 1 replies |
tyler815351411
I have developed a website using your dataassist, on the homepage there is a simply search box that search for keywords. This functions perfectly until I do the following:
If you leave the box blank and click the search button to return all results, this returns all the results fine. If you then click the back button on your browser to take you back to the home page. I then type in a keyword and hit the return button to do the search it returns all the results as it did in the last search. This problem only ever arises when you use the back button and the return key is pressed rather than the search button.
Is there anything I can do to stop this from happening Like:
Stopping the use of the return key
Stopping the back button use
or there something I can do to the search to correct this error.
Many thanks for time looking at this query, keep up the good work developing great extensions.
Kind Regards
Brian
Jimmy Wu
What browser are you using to do the search? Can you post up the url of the search page so i can take a look at the behavior?
