Created new form - doesn't load in browser
Thread begun 6/25/2010 7:53 am by dan361748 | Last modified 7/19/2010 2:00 pm by Jason Byrnes | 5150 views | 11 replies |
dan361748
Hi - I just created a new form and when I browse to the uploaded file it just displays a blank page.
I have inserted the php code to show errors at the top but nothing comes up. Otherwise I made no changes to the generated code.
Any help would be really appreciated.
Attached is my code.
1) The error reporting code is not quite correct, it should be:
error_reporting
(E_ALL);
2) your page is missing the validation toolkit include line. Add the following just after the error reporting code:
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
dan361748
Thank you Jason - should CSS Forms have inserted that code for me?
Yes, it should have.
I have never had a problem with CSS Form builder not inserting that code.
dan361748
Thank you Jason. Unfortunately this didn't fix the issue. I inserted the two lines:
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
The files were actually not generated either in the root of my site so I had to copy them from another Webassist project to this location.
Either way, I still get a blank page on load with no errors displayed. I just get a page with
<head></head>
<body></body>
and that is it.
Your assistance is appreciated.
Joyce24597
Blank page for me too
I am using the form builder for the first time and VERY FRUSTRATING. I get a blank page, I start from scratch it works but no captcha (and no instructions I can find).
Decide to start from scratch again and blank again.
This morning I can see form again after starting over again but no captcha image so I can't test the form.
I've tested with and without universal email
Joyce24597
upgrade
I checked and I forgot to upgrade to the CS5 version. I can now see captcha but won't submit. I started a new thread for that:-)
dan361748
I too am getting very frustrated with this. I have created a form with CSS Forum Builder but there is obviously some bug somewhere as both myself and the other poster here have the same issue - the completed form will not load.
Support is required for this - please help!
did you add the error reporting code at line 1 of the page:
error_reporting
(E_ALL);
can you provide a copy of the page and a link?
dan361748
Sure - here is the link:
quickquote.php
I've attached the code.
