getTagProp not defind
This was happening with CT312 installed. I've just installed v313 and still get the error.
If I try and run the behaviour "Clear Session Values" I get a warning dialog box that says:
"While executing onLoad in WACT_ClearSession.htm, the following JavaScript error(s) occurred:
At line 357 of file
"C;\Users\John\AppData\Roaming\DreamweaverCS%\en_US\Configuration\Shared|WebAssist\Cookies\Library\WA_configuration.js":
getTagProp is not defind"
I've deleted the WinCache file and recreated it. I don't really want to recreate the Configuration folder unless it's absolutely necessary and, as I've said, I've uninstalled Cookies toolkit 312 and installed CT313.
Line 357 of that file says, " return [getTagProp(tXML, "macromedia-extension", "name"), getTagProp(tXML, "macromedia-extension", "version"), getTagProp(findTag(tXML, "author", true), "author", "name")];"
Any ideas?
Unfortunately it looks like there is another extension that is interfering with that server behavior. You will have to delete the configuration directory to get around it currently. We'll have to do some more testing to look into which extension is causing the interference.
