tax not showing in confirm.php
Thread begun 6/25/2010 7:06 am by watercolor346374 | Last modified 6/30/2010 1:55 pm by watercolor346374 | 5357 views | 16 replies |
watercolor346374
The tax is not showing in the confirm.php. What is odd is that this is a formula that I have used in the past and it has shown. I have gone over my files and cannot see why it will not show. I have it set in the ecart under tax tab. Florida Tax. It is based on a session variable, countyid. I have included the files.
your confirm page does not create a session named county id, it creates a session named eCartCheckoutForm_counties
if(($row_rsCounties['countyid'] != "")) {
$_SESSION["eCartCheckoutForm_counties"] = "".$row_rsCounties['tax'] ."";
watercolor346374
still not showing
Hi Jason,
What I do not understand is why this works in another site with ecart. I set everything re the tax and tax rules identical to another site where this works. The only difference is the state. I did create the session and changed the tax rule as well as the record set and it still does not work. I get a message:
Notice: Undefined variable: row_rsCounties in /Applications/MAMP/htdocs/winkee/confirm.php on line 15
Thank you,
K
I can't say why it works in one cart and not the other.
The reason the error is occurring, is because the code to set the countyid session variable is before the code that creates the recordset, move the code to create the session so that it is after the code to create the recordset.
watercolor346374
tax still not showing
Hi Jason,
I redid the session, moved it under the rs, updated the tax rule and still no luck. Not at all sure what is going on..
thank you
send a copy of the WA_eCart/winkee_PHP.php page so i can see the tax rule.
also add the following code to the confirm page:
<pre><?php
if(!session_id()) session_start();
var_dump($_SESSION);
?></pre>
this will dump the session to the page, post this back along with the cart page.
watercolor346374
tax not showing files
Thank you,
Here are the files.
watercolor346374
tax not showing on confirm
Hi Jason,
Over the weekend I worked on this and redid the tax stuff in my cart (tax rule), confirm page(session variable) I used the session that has worked for me in the past (when I have to create a table for each county in the state that is taxed, in this case Florida) It still did not work. I am resending the info you requested.
Thank you for your help with this.
I still need you to add this code to the confirm page and post back the result:
<pre><?php
?></pre>
watercolor346374
Hi Jason,
Here are the results:
array(29) {
["cust"]=>
string(2) "55"
["total"]=>
float(20)
["shipcost"]=>
string(1) "5"
["tax"]=>
string(1) "0"
["track_num"]=>
string(0) ""
["winkee_admin"]=>
string(6) "kkbird"
["food_mart_admin"]=>
string(5) "admin"
["levelid"]=>
string(1) "1"
["shop"]=>
array(3) {
[0]=>
string(2) "32"
[1]=>
string(2) "17"
[2]=>
string(2) "15"
["pass_phrase"]=>
string(40) "3de9647ccdb3564c0083a35f26e3b3d433cb295d"
["vercode"]=>
int(83976)
["cart"]=>
array(0) {
["megan_admin"]=>
string(6) "kkbird"
["megan_isaacs_Items"]=>
string(157) "223|WAECART|2222|WAECART|bracelets|WAECART|0|WAECART|2|WAECART|50|WAECART|om12iii.jpg|WAECART||WAECART||WAECART|95|WAECART|0|WAECART|100|WAECART|2 2222 (223)"
["WAEC_ContinueRedirect"]=>
string(28) "/winkee/detail.php?prodid=41"
["winkee_Items"]=>
string(399) "46|WAECART||WAECART|Spy Tape|WAECART|0|WAECART|1|WAECART|5|WAECART|parsley.jpg20100604224337|WAECART||WAECART||WAECART|0|WAECART|12121212|WAECART||WAECART||WAECART|0|WAECART|5|WAECART|1 (46)&#65533;41|WAECART||WAECART|Black Rouched|WAECART|0|WAECART|1|WAECART|22|WAECART|chefhat.jpg20100601221932|WAECART|Long Tab|WAECART||WAECART|19|WAECART|97897979|WAECART||WAECART||WAECART|0|WAECART|22|WAECART|1 (41)"
["lolos_boutique_Items"]=>
string(457) "18|WAECART|Treasure|WAECART|Treasure Rock Angle Print Tank Ruffle Bottom with Gold Stones |WAECART|5|WAECART|1|WAECART|48.8|WAECART|small|WAECART||WAECART|0|WAECART|1|WAECART|0|WAECART|0|WAECART|0|WAECART|5|WAECART|48.8|WAECART|1 Treasure (18)&#65533;78|WAECART|Fillmore|WAECART|Fillmore, White Duck Vote Tee 2008|WAECART|5|WAECART|1|WAECART|26|WAECART|small|WAECART||WAECART|0|WAECART|1|WAECART|0|WAECART|0|WAECART|0|WAECART|5|WAECART|26|WAECART|1 Fillmore (78)"
["eCartCheckoutForm_state_province"]=>
string(2) "FL"
["eCartCheckoutForm_country"]=>
string(2) "US"
["eCartCheckoutForm_shipping_state_province"]=>
string(2) "FL"
["eCartCheckoutForm_shipping_country"]=>
string(2) "US"
["date"]=>
string(19) "2010-06-27 23:35:19"
["insert_order_status"]=>
string(7) "pending"
["eCartCheckoutForm_counties"]=>
string(5) "0.065"
["winkee_OrderID"]=>
int(124)
["megan_isaacs_OrderID"]=>
int(74)
["countyid"]=>
string(0) ""
["counties"]=>
string(5) "0.075"
["backorder"]=>
string(0) ""
array(29) {
["cust"]=>
string(2) "55"
["total"]=>
float(20)
["shipcost"]=>
string(1) "5"
["tax"]=>
string(1) "0"
["track_num"]=>
string(0) ""
["winkee_admin"]=>
string(6) "kkbird"
string(5) "admin"
["levelid"]=>
string(1) "1"
["shop"]=>
array(3) {
[0]=>
string(2) "32"
[1]=>
string(2) "17"
[2]=>
string(2) "15"
["pass_phrase"]=>
["vercode"]=>
int(83976)
["cart"]=>
array(0) {
["megan_admin"]=>
string(6) "kkbird"
["winkee_Items"]=>
string(2) "FL"
string(2) "US"
string(2) "FL"
string(2) "US"
["date"]=>
string(7) "pending"
string(5) "0.065"
int(124)
int(74)
["countyid"]=>
string(0) ""
["counties"]=>
string(5) "0.075"
["backorder"]=>
string(0) ""
Also included the file
