Inventory Level Message in Cart not showing
Thread begun 6/24/2010 10:08 pm by siteontime | Last modified 7/09/2010 10:30 am by Jimmy Wu | 4912 views | 9 replies |
siteontimeBeta Tester
Hi-
I hope you can help me with this. I can duplicate the same issue in the PowerStore Demo as well.
If I add a quantity to the cart that is more than what is left, the quantity is updated in the cart, but the message indicating that the quantity changed doesn't appear.
Here is when it shows up. If I change the quantity in the cart and hit update I get the message, or if I go back to the same item and try to add more to the cart I get the message.
How can I get this message to appear anytime the quantity is changed.
Thanks!
Jimmy Wu
That is actually how the cart is designed. You will have to click update for any changes to the cart to take place. Just changing the number in the cart without clicking update will not update the number added to the cart.
You can see what I mean by adding an item to the cart, going into the cart and changing the number without clicking update and clicking view cart again. The number of items added to the cart is the original number.
No - I think you misunderstood what I was asking.
If there are 10 in stock of an item and I add 15 to the cart. It changes the quantity added to 10, but it does not show the message that only 10 have been added. It only shows this message if I go back and try to add more or if I change the quantity and press update cart.
Here is an example on the demo store.
Products_Detail.php?ProductID=16
On the above link, try to add a quantity of 110 to the cart. It will change the quantity to 100 but will not let you know that it is doing that.
Jimmy Wu
I understand now. If you go to your Products_Details.php page and find this line:
$ATC_itemQuantity = "".((floatval($_POST["WA_Store_Cart_1_Quantity_Add"])<=floatval($row_NumLeftRS['NumLeft']) || $row_WADAProducts['ProductUnlimited'] != 0)?$_POST["WA_Store_Cart_1_Quantity_Add"]:$row_NumLeftRS['NumLeft']) ."";// column binding
You should modify it to look like this:
$ATC_itemQuantity = "".$_POST["WA_Store_Cart_1_Quantity_Add"] ."";// column binding
Thank you for your help with this. I have changed the code you posted above. The background of the quantity box now changes to red, but the message that the cart amount has been changed still does not show up unless I update the the quantity or attempt to go back and add more of the same item.
Thanks for your help with this!
Jimmy Wu
I'm not seeing any change when I test that product page. Can you send me your Products_Detail.php so I can take a look at it?
Here is a link to the detail page.
Products_Detail.php?ProductID=321
If you add a quantity of 10 to the cart you will see that it does not display the quantity changed message.
Jimmy Wu
Looks like for that store, you've cause the error message to never show up. If you modify the amount to 10 in the shopping cart, it doesn't show up either.
You would want to make sure that none of your styling has interfered with the message showing up.
Thanks - you were right. I had changed some code to try to get the error to print. I changed it back and it is working fine. Thanks for the help.
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
