Close window code you gave me works on one...
Thread begun 6/24/2010 6:38 pm by dave166439 | Last modified 6/25/2010 11:44 am by Jimmy Wu | 3033 views | 5 replies |
dave166439
but not on the other, and it is using the same index.php file as far as I can tell.
Works on this gallery:
index.php?gallery=2&theme=dark
But not here:
index.php?gallery=1&theme=dark
The code you gave me is:
<a href="#" onclick="window.close()">Close Window</a>
Please help as I have 4 more galleries to setup for this client and need to have the close window work. Thanks, Dave
neilo
Both windows (or tabs) close OK for me.
Jimmy Wu
Both links close for me as well. Which browser are you using when you test the galleries?
dave166439
Hmmm, I will try again. I was using Firefox.
Thanks for quick response. I will test in IE now.
OK, I tried in IE 8. For the work in progress, it opens in a NEW window and closes that window. For the Fireplaces, it opens in the SAME TAB and then closes the tab and the site. Is there any way to get these to behave the same as each other? Dave
dave166439
I fixed it. It needed a Target=_Blank. Works fine!
Jimmy Wu
Great to hear you were able to get this working. If you run into any additional issues, feel free to open a new thread.
