spryconfirm1
Thread begun 6/24/2010 2:25 pm by cal375160 | Last modified 6/28/2010 11:34 am by Jimmy Wu | 3943 views | 5 replies |
cal375160
spryconfirm1
I get the following message when I try to load or reload the user registration page (and probably will with others too):
Spry.ValidationConfirm ERR: The element spryconfirm1 doesn't exists!
In reading other threads on this and other sites I suspect it may be because when I applied my template to the page(s) I placed the Spry validation stuff in the <head> ? ?
In any case, the code is attached. Can someone take a look and tell me what to do?
Cal
Jimmy Wu
Could you zip up and attach the template that you used so I can take a look at that? It seems that your template is quite a complicated one.
This error didn't occur before the application of the template, is that correct?
cal375160
Zip file of template
Here is the .zip file of the template I used.
To answer your question: I applied the template before I tried the .php page, so I don't know whether or not it worked before the application of the template.
Hope you can help.
Cal
Jimmy Wu
You want to add an additional editable region that looks like this:
<!-- TemplateBeginEditable name="SpryValidation" -->
<!-- TemplateEndEditable -->
right before the closing body tag for your template. Adding the spry validation to the head causes the error.
I would recommend downloading the files again and starting with fresh files and then applying the updated template to the pages.
cal375160
Thanks!
Thank you. Problem solved (I think).
Cal
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
