Big Problem
Thread begun 6/24/2010 10:03 am by Gabriel Tiviroli | Last modified 6/24/2010 4:34 pm by Jimmy Wu | 2023 views | 2 replies |
Gabriel Tiviroli
Big Problem
Friends I have a problem with the Security Assist, as I implemented the login system and while in local mode works perfectly, on the remote server I get the following error: Parse error: syntax error, unexpected $ end in / home / committee / public_html / administradores_LogIn.php on line 58
Here I leave the page code for tests to see if I can help.
if (!isset($_SESSION)) {
session_start();
?><?php require_once('Connections/comitemexicano.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?><?php
if ((((isset($_POST["autologinoption"]))?$_POST["autologinoption"]:"") != "")) {
setcookie("AutoLoginPWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("AutoLoginUN", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if ((((isset($_POST["remembermeoption"]))?$_POST["remembermeoption"]:"") != "")) {
setcookie("RememberMePWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "".((isset($_POST["username"]))?$_POST["username"]:"") ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if (isset($_POST["LogIn_x"]) && !isset($_POST["remembermeoption"])) {
setcookie("RememberMePWD", "", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "", time()+(60*60*24*30), "/", "", 0);
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $comitemexicano,
"database" => $database_comitemexicano,
"tableName" => "administradores",
"columns" => explode($WA_Auth_Separator,"usuario".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"administradorid"),
"sessionNames" => explode($WA_Auth_Separator,"administradorid"),
"successRedirect" => "Admin/index.php",
"failRedirect" => "index.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
if((((isset($_SESSION["administradorid"]) && $_SESSION["administradorid"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
"columnValues" => explode($WA_Auth_Separator,"".((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") ."".$WA_Auth_Separator."".((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") .""),
Gabriel Tiviroli
Problem solve
The problem has been solve
Jimmy Wu
Good to hear you were able to get your issue resolved. If you run into any additional issues, feel free to open a new thread.
