Creating a PHP database connection: Dreamweaver error
Thread begun 6/23/2010 3:55 pm by designate407706 | Last modified 7/14/2017 11:06 am by Ray Borduin | 8763 views | 34 replies |
designate407706
I'm following the instructions in creating_db_connection.php
See the enclosed images.
I'm trying to set up the db connection in Dreamweaver. When I go to *select* the db, I get an error (see enclosed). I think it is essentially saying that I do not have a testing server running on the server machine.
I have MAMP running (I'm on a Mac; both Apache and MySQL servers seem to be fine) and PHPMyAdmin running in my browser.
What am I doing wrong?
In your site definition, on the testing server tab, you have entered 127.0.0.1/ as the URL prefix.
try using localhost/ instead
913 MediaWorks
MAMP folder settings
just to venture a guess, did you change the default folder path for MAMP?
I had pointed mine into the /usr/... folder (and changed the port #'s to standard) and had the same error. setting the folder path back to the MAMP default solved my problem (left the ports at 80 and 3306, tho).
hope that solves your issue.
- trent
designate407706
Originally Said By: robert329616
- trent
I don't know how to change the default folder for MAMP, so don't think I did that. I have those ports as you spec too.
designate407706
I do not have 127.0.0.1/ entered
I do have localhost/ entered.
designate407706
localhost selected
see screenshot
913 MediaWorks
I somewhat mis-spoke. Rather than the default MAMP folder, I meant the 'Document Root' setting in the Apache tab (in the MAMP preferences).
- trent
designate407706
mamp apache doc root
- trent
Didn't know I could change that either. I'm a newbie, first time doing this.
doc root is /Applications/MAMP/htdocs
913 MediaWorks
dreamweaver site definition setup
don't forget your site folder in your path. and the trailing slash in the URL prefix. I included screenshots of my local and testing setup.
- trent
designate407706
larger images
i can't read those they are too small. THANKS so much though for helping!!
