"Setting" link logging me out!
Thread began 6/23/2010 3:36 pm by ow244048 | Last modified 7/01/2010 12:53 pm by Jimmy Wu | 2226 views | 7 replies |
ow244048
Hello, just installed PowerCMS 2.0.1 and have this strange problem: When I click on the "Settings" tab (settings.php) or sometime when I just try to add content item, I find myself in the log-in page (i.e. I was thrown out)...
Please advise
Jimmy Wu
This most likely has to do with how the session management is handled on your server. You should contact your server administrator or hosting provider to see if there are any special session management rules set up.
ow244048
I have other PHP scripts on this server with no problem at all (include PowerCMS ver 1)... one thing that comes to mind is that I'm working with a temp. domain name (www.ultrasoniccleaner.com.php5-12.dfw1-2.websitetestlink.com)... any chance that there is a link to that?
Also, what about documents permission settings. was there any permission setting i had to configure?
ow244048
Please any one at WA please take a look ASAP:
the site address is users_login.php
user: admin
pwd: ultraAdmin19
Need a solution today ASAP!
Jimmy Wu
It looks like the login credentials were changed. Someone else may have logged into your CMS, since this is a public forum, other users can see your login information as well.
It shouldn't have anything to do with being on a temporary domain name. You shouldn't be logged out because of a permissions issue on any of the files either.
Does this consistently occur or is it something that happens only some of the time?
ow244048
No one changed the password. This is the problem!
I also have a suspicion that the user and password were never saved on the database.
Not worry now about the public see user and pwd, I'll change it later. I need to resolve this issue ASAP. Would you be able to contact me? I'm behind on this project, and it might cost me dearly.
Jimmy Wu
I've opened up a backend ticket to look into this issue with you further. To check your backend ticket, log in to your account at www.webassist.com and check your support history.
Jimmy Wu
The issue turned out to be a session variable issue that was handled through the .htaccess file.
