ecart, not showing backorder message
Thread begun 6/23/2010 1:23 pm by watercolor346374 | Last modified 7/01/2010 6:44 pm by Eric Mittman | 3487 views | 5 replies |
watercolor346374
Hello,
I have been attempting to show a message on the detail page in the cart area that tells a client when a product is on backorder...nothing seems to work. When I have done it in plain old code it works. I have included the detail page to show you what I have done so far, then I want to have the backorder statement shown in the cart under the size the customer has chosen.
thank you,
It looks like the criteria that you are using to display the message is:
<?php if ($row_rsSize['quantity']!= "0") { // Show if recordset empty ?>
echo $row_rsSize['backordermsg']; ?>
This rsSize recordset looks like one that you are using for the values of the item. It looks like you have another recordset called inventory that should check on the inventory of the current item. Is this what you would like to use to determine if the item is on backorder? If so you should check the rsInventory recordset and check on the column in the table that lets you know the stock. When you check this stock you just need to see if is < 1, if so you should display the out of stock message.
watercolor346374
backorder message in cart
Hi Eric,
You are correct at what I am attempting to do. As you suggested I used the rsInventory. I played with the statement: <?php if ($row_rsInventory['quantity'] = 0) { // Show if recordset empty ?>
Made it <1 made it 0 made it ==0 and could not get it to work. Seems that this should work. Am I missing something?
Thank you
The if statement that you have now is setup like this:
echo $row_rsInventory['backordermsg']; ?>
To make it so this message will only show if there is not at least one item available it should look like this:
<?php if ($row_rsInventory['quantity'] < 1) { // Show if recordset empty ?>
This is saying that if the current row in the rsInventory recordset for the quantity column is less than 1, then display the value backordermsg from the rsInventory recordset for the current row. If you do not see the message then it would indicate that the value from this column is 1 or greater. If you have any further problems with this you should check your db for the specific record involved to see what the exact values are for these columns.
watercolor346374
backorder message to show in cart
Hi Eric,
Your help worked. Now I want to have the backorder msg show in the cart underneath the size. I inserted what you showed me into the cart:
<td><?php echo $winkee->DisplayInfo("Tab"); ?>
<?php if ($row_rsSize['quantity'] < 1) { // Show if recordset empty ?>
<?php echo $row_rsSize['backordermsg']; ?>
<?php } // Show if recordset empty ?> </td>
I change the rsInventory to rsSize and created the rs rsSize with the prodid=prodid...did not work. I played around with the filter and nothing worked. When I set up my cart I did include a column that is BO and that did not work. Some of the items do not have sizes, so I have an inventory table. If a product has sizes the prodid is posted on the inventory table, and given an inventory id. How do I get the cart to pick up the inventoryid for the size and post the message in the cart under the size?
Thank you,
K
In order to show a message like this in your cart you would need a way to compare the value for the current item to the available quantity amount. Doing this with a recordset like this is not going to work because the first record in the recordset might not match up for the current item.
Getting this message to show in the cart is going to be a custom endeavor that require hand editing of the code to get it worked out and is not supported. One way that I can think of to do something like this would be to have the recordset and the code that checks against it inside of the eCart loop. You could then have a new recordset that is filtered for the current item on each loop of the cart. You can then have your check in place to show the message based on the recordset value compared to the value of the current item in the cart.
