array checkbox breaks form validation
Thread begun 6/23/2010 10:19 am by ijs174940 | Last modified 6/24/2010 10:48 am by Jason Byrnes | 5133 views | 12 replies |
ijs174940Beta Tester
Currently using CCS Form Builder 1.0.2 in CS4 and I have run into a problem validating my form, so i made a clean page and rechecked but got the same result. If I add a few fields and checkboxs named them and set the values the validation works fine but if I change the names of the checkboxs to arrays as in add "[]" to the end of the name the validation stops??
example
<form action="" method="post" name="form1" id="form1" onsubmit="WAValidateRQ(document.form1.testtext,'text box required',document.form1.testtext,0,false,'text');WAValidateRQ(document.form1.checkbox[],'check box requiired',document.form1.checkbox[],0,true,'checkbox');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue">
<p>
<label>
<input type="text" name="testtext" id="testtext" />
</label>
</p>
<p>
<label>
<input type="checkbox" name="checkbox[]" id="checkbox[]" value="1"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" id="checkbox[]" value="2"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" id="checkbox[]" value="3" />
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" id="checkbox[]" value="4"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" id="checkbox[]"value="5" />
</label>
<label> </label>
<label><br />
</label>
</p>
<p>
<label>
<input type="submit" name="button" id="button" value="Submit" />
</label>
</p>
</form>
Is this a limitation of the extension or a bug?
Thanks for any input guys...
add the validation to the checkboxes before changing the name to create an array.
the validation code will use the name of the form element, but in the case of a checkbox array group, the name must contain the "[]" but the referance must not.
in other words, the validation code:
<form action="" method="post" name="form1" id="form1" onsubmit="WAValidateRQ(document.form1.testtext,'te xt box required',document.form1.testtext,0,false,'text'); WAValidateRQ(document.form1.checkbox[],'check box requiired',document.form1.checkbox[],0,true,'checkbox');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),fa lse);return document.MM_returnValue">
is referencing the checkbox elements as:
when the proper reference is:
the proper code will be created if you add the [] to the checkbox name after adding validation.
Hi Jason
tried this but same result no validation, am I missing something?
<form action="" method="post" name="form1" id="form1" onsubmit="WAValidateRQ(document.form1.testtext,'test is required',document.form1.testtext,0,false,'text');WAValidateRQ(document.form1.checkbox,'check box is required',document.form1.checkbox,0,true,'checkbox');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue">
<p>
<label>
</label>
</p>
<p>
<label>
<input type="checkbox" name="checkbox[]" value="1"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" value="2"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" value="3" />
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" value="4"/>
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" value="5" />
</label>
<label> </label>
<label><br />
</label>
</p>
<p>
<label>
</label>
</p>
</form>
post a link please
The site is my office local server no live link
can you post a copy of the page then please.
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>The Little White Van Company - Online Print Toolkits</title>
function WAtrimIt(theString,leaveLeft,leaveRight) {
if (!leaveLeft) {
while (theString.charAt(0) == " ")
theString = theString.substring(1);
if (!leaveRight) {
while (theString.charAt(theString.length-1) == " ")
theString = theString.substring(0,theString.length-1);
return theString;
function WAFV_GetValueFromInputType(formElement,inputType,trimWhite) {
var value="";
if (inputType == "select") {
if (formElement.selectedIndex != -1 && formElement.options[formElement.selectedIndex].value && formElement.options[formElement.selectedIndex].value != "") {
value = formElement.options[formElement.selectedIndex].value;
else if (inputType == "checkbox") {
if (formElement.length) {
for (var x=0; x<formElement.length ; x++) {
if (formElement[x].checked && formElement[x].value!="") {
value = formElement[x].value;
break;
else if (formElement.checked)
value = formElement.value;
else if (inputType == "radio") {
for (var x=0; x<formElement.length; x++) {
break;
else if (inputType == "radiogroup") {
break;
else if (inputType == "iRite") {
var theEditor = FCKeditorAPI.GetInstance(formElement.name) ;
value = theEditor.GetXHTML(true);
else {
var value = formElement.value;
value=value.replace(/<p>(\&\#160\;)*<\/p>/,"");
if (trimWhite) {
value = WAtrimIt(value);
return value;
function WAAddError(formElement,errorMsg,focusIt,stopIt) {
if (document.WAFV_Error) {
document.WAFV_Error += "\n" + errorMsg;
else {
document.WAFV_Error = errorMsg;
if (!document.WAFV_InvalidArray) {
document.WAFV_InvalidArray = new Array();
document.WAFV_InvalidArray[document.WAFV_InvalidArray.length] = formElement;
if (focusIt && !document.WAFV_Focus) {
document.WAFV_Focus = focusIt;
if (stopIt == 1) {
document.WAFV_Stop = true;
else if (stopIt == 2) {
formElement.WAFV_Continue = true;
else if (stopIt == 3) {
formElement.WAFV_Stop = true;
formElement.WAFV_Continue = false;
function WAValidateRQ(formElement,errorMsg,focusIt,stopIt,trimWhite,inputType) {
var isValid = true;
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
if (!document.WAFV_Stop && !formElement.WAFV_Stop) {
var value=WAFV_GetValueFromInputType(formElement,inputType,trimWhite);
if (value == "") {
isValid = false;
if (!isValid) {
WAAddError(formElement,errorMsg,focusIt,stopIt);
function WAAlertErrors(errorHead,errorFoot,setFocus,submitForm,allowOverride) {
if (!document.WAFV_StopAlert) {
document.WAFV_StopAlert = true;
if (document.WAFV_InvalidArray) {
var errorMsg = document.WAFV_Error;
if (errorHead!="")
errorMsg = errorHead + "\n" + errorMsg;
if (errorFoot!="")
errorMsg += "\n" + errorFoot;
document.MM_returnValue = false;
if (document.WAFV_Error!="") {
if (allowOverride) {
if (confirm(errorMsg.replace(/&quot;/g,'"'))) {
document.MM_returnValue = true;
return;
else {
alert(errorMsg.replace(/&quot;/g,'"'));
else if (submitForm)
submitForm.submit();
if (setFocus && document.WAFV_Focus) {
if (document.getElementById(document.WAFV_Focus.name+"___Config") && document.WAFV_Focus.type.toLowerCase() == "hidden") {
var theEditor = FCKeditorAPI.GetInstance(document.WAFV_Focus.name);
theEditor.EditorWindow.focus();
setTimeout("setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
document.tempFocus = document.WAFV_Focus;
setTimeout("document.tempFocus.focus();setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
for (var x=0; x<document.WAFV_InvalidArray.length; x++) {
document.WAFV_InvalidArray[x].WAFV_Stop = false;
else {
if (submitForm) {
document.WAFV_Focus = false;
document.WAFV_Error = false;
document.WAFV_InvalidArray = false;
</script>
</head>
<body>
<form action="" method="post" name="form1" id="form1" onsubmit="WAValidateRQ(document.form1.testtext,'text is required',document.form1.testtext,0,false,'text');WAValidateRQ(document.form1.checkbox,'check box is required',document.form1.checkbox,0,true,'checkbox');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue"> <p>
<label>
</label>
</p>
<p>
<label>
</label>
<label> <br />
</label>
<label> <br />
</label>
<label> <br />
</label>
<label> <br />
<input type="checkbox" name="checkbox[]" id="checkbox[]" value="5" />
</label>
<label> </label>
<label><br />
</label>
</p>
<p>
<label>
</label>
</p>
</form>
</body>
</html>
only the name should contain the square brackets, not the id. For example, instead of:
use:
<input type="checkbox" name="checkbox[]" id="checkbox" value="1"/>
That works partly as if i submit with out selecting or adding content I get the correct warning for both form elements but if I tick one of the check boxs excluding the first only and I dont add the required text to the field I get the same warning about both missing. It appears that only the first box being ticked will prevent this from happening.
However by selecting any check box and adding the required text the form submits as it should so while the validation does work it could cause confusion if the final user selects the options oulined above.
I am not sure there is a workaround for this.
i have now tried this in the real code and I am hitting an error which is related to the previous post
///this is the form tag///
<form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>" method="post" name="LWV_1_ATC_0" id="LWV_1_ATC_0" onsubmit="WAValidateRQ(document.LWV_1_ATC_0.LWV_1_Quantity_Add,'Please enter the quantity you require.',document.LWV_1_ATC_0.LWV_1_Quantity_Add,0,false,'text');WAValidateRQ(document.LWV_1_ATC_0.Pub,'Please select which venues are to receive this design.',document.LWV_1_ATC_0.Pub,0,true,'checkbox');WAValidateRQ(document.LWV_1_ATC_0.designtype,'Please select the type of design you require.',document.LWV_1_ATC_0.designtype,0,true,'select');WAValidateRQ(document.LWV_1_ATC_0.designsize,'Please select what size you require for this design.',document.LWV_1_ATC_0.designsize,0,true,'select');WAAlertErrors('The following option(s) are required before we can add this design to you order\n\n','\n\nIf you are experiancing issues this order please call our support team on : 0844 504 6914 \n',false,document.getElementById('LWV_1_ATC_0'),false);return document.MM_returnValue">
///this is the checkbox loop //
<?php if (isset($_SESSION['site_lvl'])) {?>
<fieldset><legend><span class="logintxt">Venues to recieve this design</span></legend>
<input name="allbox" type="checkbox" onclick="flevToggleCheckboxes('LWV_1_ATC_0',true,false)" value="on" /> Select all venues<br />
<?php do { ++$i ?>
<input type="checkbox" <?php if (in_array($row_rs_member_list['ID'], $SelectedPubList, TRUE)) {echo "checked=\"checked\"";} ?> name="Pub[]" value="<?php echo $row_rs_member_list['ID'];?>" id="Pub" />
<?php echo $row_rs_member_list['PUB_NAME']; ?><br />
<?php } while ($row_rs_member_list = mysql_fetch_assoc($rs_member_list)); $i=0; ?><br /><input name="Re-calculate" class="cust_button" type="submit" value="Re-calculate" />
</fieldset>
<?php } ?>
It appears that unless I tick the first checkbox in the list I get the validation error, totally confused now
