Problems with coordinates from database
Thread begun 6/23/2010 3:34 am by info406782 | Last modified 7/12/2010 12:20 pm by Jason Byrnes | 3070 views | 8 replies |
info406782
Hi, I'm searching to create a map with multiple coordinates records extract from a database, but the map isn't show correctly.
Here is the page that I obtain:
mappa.asp
please send a copy of your google_javascript/wagmp_map_2.php file
info406782
wagmp_map file
here is .asp file
info406782
Hi, can you help me soon. I must deliver the website 5 july 2010.
i am sending a copy of the google_javascript/wagmp_map_2.asp file that has been update to correct the problem.
info406782
error
Hi Jason,
I have uploaded the new wagmp_map_2.asp file, but it doesn't work. Now there is only 2 marker on the map instead 3 but only one is on the right point, the other is on map border.
the first coordinates you have:
Lat: ‪36.895024 Long: 14.702003
Are not recognizerd by google.
Go to maps.googel.com and enter:
36.895024, 14.702003
in the search field, google can not plot this latitude and longitude.
info406782
If I search this coordinates 36.895024, 14.702003 with google maps I obtain this:
maps?f=q&source=s_q&hl=it&geocode=&q=36.895024,+14.702003&sll=41.442726,12.392578&sspn=24.229039,46.977539&ie=UTF8&t=h&z=17&iwloc=near
It look like good. It is the right point to mark.
these coordinates do not work however:
36.888640, 14.691736‬
try testing all three of your coordinate values.
