Flash Player Running Slowly
Thread begun 6/21/2010 2:18 pm by todd362168 | Last modified 6/23/2010 11:02 am by mr hankey | 2715 views | 4 replies |
todd362168
After adding a simple dynamic data chart to an ASP page, the chart does not display. But after about 10 seconds a windows error dialog box appears stating " A script in this movie is causing Abode Flash Player 10 to run slowly. If it continues to run, your computer may become unresponsive. Do you want to abort the script?"
Anyone seen this and figured it out?
my guess is that you are using dynamic data in the chart, and the dataset returned from the database is extremely large causing the flash script to time out.
you may need to set the dynamic data section to more aggressively filter the database.
todd362168
Thanks Jason, wish it were that simple. The dynamic dataset was a simple test table with 3 entries. Has no one else ever seen this error?
not that I am aware of, can you provide a link please?
mr hankey
I get this error with small amounts of data.
it is only in DWCS3 i get it though, if i do the chart in DWCS4 it runs fine.
DWCS3 adds a <NOSCRIPT> tag and javascript around the flash file.
remove the script and it should run fine.
