1 out of 3 search fields works
Thread began 6/21/2010 9:25 am by mr hankey | Last modified 6/23/2010 11:24 am by Eric Mittman | 1202 views | 3 replies |
mr hankey
hi,
only search element that works is a select list menu, the other 2 which 1 is a date range does not work, php code generated by data assist:
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADApipeline;
//Searchpage: product_Results.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr0 = array("ClientLastName");
$KeyArr1 = array("Product");
//comparison list additions
$WADbSearch1->addComparisonFromEdit("DueDate","FromDate","AND",">=",2);
$WADbSearch1->addComparison("DueDate","".WAQB_getEndDate($_POST["ToDate"]) ."","AND","<=",2);
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["ClientLastName"]))?$_POST["ClientLastName"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["Product"]))?$_POST["Product"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_product_Results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_product_Results"]) && $_SESSION["WADbSearch1_product_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_product_Results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
my form:
<form name="form1" action="product_Results.php" method="post">
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="right"><label >Due Date Range From:</label></td>
<td><input type="text" name="FromDate" value="" />
&nbsp;
<label>To:</label>
&nbsp;
<input type="text" name="ToDate" value="" />
&nbsp;(mm/dd/yyyy)</td>
</tr>
<tr>
<td align="right"><label for="ClientLastName">Client Last Name:</label></td>
<td><input type="text" name="ClientLastName" value="" /></td>
</tr>
<tr>
<td align="right"><label for="Product">Product:</label></td>
<td><select name="Product">
<option value="product1">product1</option>
<option value="product2">product2</option>
</select></td>
</tr>
<tr>
<td align="center" ><input type="submit" name="WADbSearch1" value="Search" /></td>
</tr>
</table>
</form>
my search form is on my results page.
tried deleting the behaviour and going through the wizard again but still no joy.
thanks
In regards to the searches that you have setup that are not working how are they configured in the DataAssist Search server behavior that is on the results page? Please review how they are setup, and include information about these columns in your db and what you are shooting for as an end result.
mr hankey
hi Eric,
End Result:
i want the other 2 search fields to work, at moment it just gives me no results.
the setup of the data assist is on my original post. that is what it produced.
date range is a date column type, client last name is a varchar column type in database.
thanks
Please post back with the page in question, a copy of your db, and your WA_DataAssist folder from your site in a zip archive. Along with this please also describe how you have currently configured the criteria for this particular search that is not working. I will use your files and info to try and determine what needs to be done to make it work.
