CSS Sculptor js problem
Thread begun 6/20/2010 12:13 am by njmoore98184 | Last modified 6/21/2010 11:22 am by Jimmy Wu | 1985 views | 2 replies |
njmoore98184
The first time I used CSS Sculptor, yesterday - no problem. Now, the following day when I try to create a new CSS Sculptor page get a message "While executing onLoad in wacs_quickinsert.htm the following Javascript error occurred:
In file "wacs_quickinsert" initialise UI is not defined.
So I cannot get any further - I've uninstalled the extension, reinstalled it, even re downloaded it from the WA site, but it still won't work! HELP please ...
njmoore98184
Css Sculptor
Hi, found a solution from Jason Byrnes
This is a common error in DW CS4 that has a simple solution.
Delete the Dreamweaver Cache file from the user configuration folder:
technote...ion_issues.pdf
It worked for me
Jimmy Wu
Yes, some of the js errors can be resolved by following those steps. If you try that and still run into problems, make sure you make a new thread and say that you already tried that solution.
