Content area not showing and JS error
Thread began 6/19/2010 9:42 pm by Peter | Last modified 6/21/2010 3:06 pm by Eric Mittman | 928 views | 1 replies |
Peter
The content area isn't showing at all below the buttons on the page. When I tried to go back in to edit the form, I get a javascript error (which by the way is not an uncommon experience while using my WA extensions). I did delete my wincachefile.dat file or whatever it's called and re-started my DW CS5 to no effect, still get the error. Any thoughts on fixing the situation are appreciated. See the attached screen capture of my error message.
There might be a corruption of your configuration folder that is causing this problem. Here are the steps that you can take to undo any corruption by having DW recreate the folder for you:
showpost.php?p=12293&postcount=2
Please let us know if you experience any further errors or problems with the editor that you add to the page.
