Ecart Object Issue
I am trying to start an Ecart Object and getting a message that Panel 162 could not be created - Removing it from the list
go to:
Window -> Workspace Layout -> Reset '<Your Layout Name>'
then delete the Dreamweaver cache file from the users configuration folder:
not sure what layout to remove sine i never set one up, still the dreamweaver defaults
You will only be able to reset your active layout.
in the path:
substitute <Your Layout Name> with the name of the layout you are using.
