Need some help setting up a calculation rule please...???
Thread begun 6/18/2010 8:35 pm by angelleye | Last modified 8/16/2010 8:22 am by Jason Byrnes | 6520 views | 16 replies |
angelleye
I've got an item that we sell for $49.99 but if you add more than 1 of that particular item you get the extras at $15/each. For example, if you buy 3 of them the line item total would be $79.99. This is only for that item, though, so it needs to be based on the ID or something..??
Any information would be greatly appreciated. Thanks!
You can do this as a discount using the item ID as the trigger.
For the trigger select "Number of Items with a Specific Column Value":
Number of items where 'ID' has a value of '1' is '>' a value of '1'
This assumes the discount is applied to item ID 1, change this to the ID you wish to use.
For the discount calculation use "Based on Multiple of Column Subtotal":
SubTotal of Column 'Quantity' 'Times' '34.99' 'Minus' '34.99'
angelleye
perfect!
Works perfectly. Thanks!!
angelleye
whoops...
I take that back. It works as expected when that item that gets discounted is the only item added in the cart. When I add other items as well, though, it's not adding up. It seems to be applying the discount to ALL extra items in the cart. Not just the items that have the particular ID. I set it up just how you said, though, except for some pricing changes.
The item ID I need to discount for extras is 2. The price of the first one is $49.97 and the price of the additional ones is $15.00. This should only apply for this particular item. All other items should increment their price like normal. Here's a screen-shot of what I did based on your reply...
After applying that rule I go to the site and add the software item multiple times and it correctly calculates a discount to give me the expected grand total. Here's a screen-shot of that, working as expected...
The problem is if I have other items with different ID's it's applying them to the discount. For example, I have another item that is $49.97 as well, but it doesn't get discounts for additions. It's not working out that way, though. Here's a sample of 2 software items (where the second should get the discount) and 1 hardware item that shouldn't be discounted at all.
As you can see it's still giving the same break-down simply because there are 3 total items in the cart. What I need, though, is for the grand total in this last example to be $114.94. That breaks down to $49.97 for the first software item, $15.00 for the second one, and then $49.97 for the hardware item.
Any information on what I did wrong here would be greatly appreciated. Thanks!
CraigRBeta Tester
dirty fix ?
Jason may well have a better solution, but after fiddling for a while, i got this to work...
Set the calculation to flat rate.
set the discount to...
((floatval($this->GetInfo("2", "Quantity")) * 15)-15)
where 2 is the ID of the product
this should discount $15 for each item after the first for the product id 2 (only).
Good one Craig, that's an excellence fix, not dirty at all.
angelleye
screenshot?
Can you show me a screen-shot of how to set that up? I'm a little confused with the drop-downs. Do I just set it to Flat rate and put in that calculation, or what? And what do I do for condition in that case? Just a basic one to ensure items are in the cart..??
angelleye
cool!
Looks like that got me there. I actually need to discount 34.97 after the first one because the additional unit price should be $15, but yeah, this seems to be working. Thanks guys!
excellent, glad to her it is working.
angelleye
ugh!
Again, I take that back. Now it's adding the $34.97 to my hardware product if I don't have software included in the cart.
Here's what I'm working with: product-list.php
As long as their is at least 1 software item (id 2) added to the cart it's calculating things correctly. When I don't have software added, though, it's adding the 34.97 to the price of the hardware and throwing that into the total. So the subtotal shows the correct price of $49.97 but then the Grand Total is showing 84.94. It's not showing my the discount lines in the summary, though, so I'm a little confused here.
