add to cart button on results page
Can I set up an 'add to cart' button on the results page with eCart 4, like this cart?
prints_archive.php
She will not be using options and really wants an 'add to cart button on the main results page.
prints_archive.php
Yes, you can add the Add to Cart button to the results page.
On the first page of the Add to cart button wizard, select the option to Lookup Item ID From recordset. Select your recordset and the ID column.
On the bindings tab, bind each of the cart columns to the corresponding column from the recordset.
Jason, can this also be accomplished easily with PowerStore?
Only you do not offer product options. If you offer product options, this will not be easily accomplished.
