customizing CSS
Thread began 6/17/2010 3:10 pm by steven371033 | Last modified 6/24/2010 10:16 am by Jimmy Wu | 1298 views | 3 replies |
steven371033
customizing CSS
If I choose a design besides Cabo Sunset and try and customize the CSS with header, footer etc. it always reverts to Cabo Sunset.
So how can I get past that?
I have downloaded the latest version. I am on a Mac Pro with Snow Leopard using DW CS4.
Jimmy Wu
I am attaching an updated version of the wacs_quickinsert.js file that you should replace your current one located in the Commands directory within the Configuration directory referenced in the common installation issues file:
Note the common installation issues is referenced just to get the location of the Configuration directory. It is not necessary to delete the Win/Mac FileCache fileunless there are any js errors that occur after making the change to the wacs_quickinsert.js file.
wacs_quickinsert.js.zip
deb364196
customizing css
Will this fix also work for pc users, using CS4?
thx
Jimmy Wu
Yes, this fix would work for you as well. Give it a try and make sure you shut down Dreamweaver before you replace the file.
