Free Shipping for a particular item
Thread begun 6/17/2010 2:47 pm by Armen | Last modified 6/22/2010 4:36 pm by Eric Mittman | 3877 views | 7 replies |
Armen
I'm using: DW CS4, eCart 4.5.2, VBScript/ASP/MS SQL
How do i set one particular item to free shipping? This item will be shipped free while everything else will have its shipping calculated normally based on weight. I currently have everything being calculated based on weight and need to offer free shipping on a 'special' item.
If the shipping is only based on weight then you could make sure the product does not have a weight associated with it to avoid having shipping charged for it.
Armen
UPS does not allow the shipping (or looking up the pricing for) an item with a weight of zero.
If the only item in the cart has no weight associated with it you will have this problem. To get around this you can add in an extra condition to the shipping server behavior on your confirm page. You would want to check the total of the total weight column being greater than 0. If you can post back with the page in question minus any sensitive details I can show you an example of what I mean.
Armen
if (Request.ServerVariables("Request_Method") = "POST") then
'WA eCart (Copyright 2007, WebAssist)
'WA eCart UPS Shipping - UPS
Dim Shipping_SuccessURL, Shipping_FailureURL, Shipping_Packaging, Shipping_PackageIndex, Shipping_Counter, Shipping_Parameters, Shipping_SubPackage, Shipping_PackageArray
set Shipping_Parameters = new WA_eCart_UPS_Parameters
set Shipping_SubPackage = new WA_eCart_UPS_Package
Shipping_SuccessURL = ""
Shipping_FailureURL = "shipping_failure.asp"
Shipping_Packaging = 0
Shipping_PackageArray = Array()
Shipping_PackageIndex = 0
Shipping_Counter = 0
Shipping_Parameters.ShiptoCity = "" & cStr(Request.Form("shipping_city")) & ""
Shipping_Parameters.ShiptoState = "" & cStr(Request.Form("shipping_state_province")) & ""
Shipping_Parameters.ShiptoZip = "" & cStr(Request.Form("shipping_postcode")) & ""
Shipping_Parameters.ShiptoCountry = "" & cStr(Request.Form("shipping_country")) & ""
Shipping_Parameters.UserID = ""
Shipping_Parameters.Password = ""
Shipping_Parameters.AccessKey = ""
Shipping_Parameters.CarrierCode = ""
Shipping_Parameters.PickupType = ""
Shipping_Parameters.CustomerClass = ""
Shipping_Parameters.ShipperNumber = ""
Shipping_Parameters.ShipperCity = ""
Shipping_Parameters.ShipperState = ""
Shipping_Parameters.ShipperZip = ""
Shipping_Parameters.ShipperCountry = "US"
while ((Shipping_Packaging = 1 AND not WA_eCart_EOF(neoCart)) OR (Shipping_Packaging = 0 AND Shipping_Counter = 0))
if (WA_eCart_UPS_IsTrueValue("true")) then
ReDim Preserve Shipping_PackageArray(Shipping_PackageIndex+1)
if (Shipping_Packaging = 1) then
Shipping_SubPackage.eCart_Quantity = WA_eCart_DisplayInfo(neoCart, "Quantity")
else
Shipping_SubPackage.eCart_Quantity = 1
end if
Shipping_SubPackage.IsPackage = "true"
Shipping_SubPackage.Quantity = "1"
Shipping_SubPackage.WeightUnits = "LBS"
Shipping_SubPackage.PackageWeight = "" & cStr(WA_eCart_DisplayInfo(neoCart, "TotalWeight")) & ""
Shipping_SubPackage.PackageType = "02"
Shipping_SubPackage.SizeUnits = "IN"
Shipping_SubPackage.PackageLength = "12"
Shipping_SubPackage.PackageWidth = "12"
Shipping_SubPackage.PackageHeight = "8"
'Special Services
set Shipping_PackageArray(Shipping_PackageIndex) = Shipping_SubPackage
Shipping_PackageIndex = Shipping_PackageIndex+1
end if
Shipping_Counter = Shipping_Counter + 1
set neoCart = WA_eCart_MoveNext(neoCart)
end if
wend
set neoCart = WA_eCart_MoveFirst(neoCart)
end if
Shipping_Result = WA_eCart_UPS_GetRateQuote(neoCart, Shipping_Parameters, Shipping_PackageArray)
if (Shipping_Result) then
if (Shipping_SuccessURL <> "") then
neoCart_redirStr = Shipping_SuccessURL
end if
elseif (Shipping_FailureURL <> "") then
Response.Redirect(Shipping_FailureURL)
end if
elseif (cStr(Session("neoCart_UPS_Success")) = "") then
WA_eCart_UPS_SetSessionDefaults(neoCart)
end if
Session("eCartCheckoutForm_shipping_country") = "" & cStr(Request.Form("shipping_country")) & ""
end if
Session("eCartCheckoutForm_shipping_postcode") = "" & cStr(Request.Form("shipping_postcode")) & ""
end if
Session("eCartCheckoutForm_shipping_state_province") = "" & cStr(Request.Form("shipping_state_province")) & ""
end if
In the code that you posted you will want to add an if statement around the shipping quote server behavior like this:
if (WA_eCart_TotalColumn(neoCart, "TotalWeight") > 0) then
***server behavior code here***
end if
end if
Armen
I added the code and it works when the only item in the cart is the one with the free shipping (item weight of zero). When I add another item to the cart and and attempt to checkout, I get an error message from the UPS quote: No Packages to Ship
The code that I added should only skip over the server behavior if there are no items with a weight in the cart. If you are getting an error it means that the server behavior is being triggered so it seems that there might be another issue occurring in the server behavior. Have you tried this out with a few different items by themselves and together to see if you get this same result?
If you are getting it regularly then you should add in the USPS full request and full response to your failure page that you are getting to. These should be available to you in the bindings tab, just drag and drop them onto the page. If you have any trouble with the info that you get post back with the details so we can look into it with you.
