DA 207 database error handling
Thread begun 6/17/2010 2:18 pm by rick178787 | Last modified 6/21/2010 12:18 pm by Jimmy Wu | 3287 views | 5 replies |
rick178787
in MySql I set up an index with the attribute of "unique" on one of the columns to keep from getting duplicate entries. It works as it should and when I enter a dupe the Insert.php DA 207 Wizard handles the error with the rather cryptic:
Duplicate entry 'books' for key 2
where "books" is the duplicate word I tried to add.
Usually in php I see lines of code dealing with error handling but I don't see where this command is generated. I suppose this is coming from SSI but I can't backtrack far enough to locate the code and put a more user friendly message in.
Any ideas?
Rick
Jimmy Wu
This looks like the error generated by MySQL. The code written by DataAssist will have the query to insert like this:
mysql_query(<query here>) or die(mysql_error());
If there's an error, then it displays the mysql_error(). If you wanted to output something other than the default mysql_error, you would want to check the mysql_errno() and output different messages based on the error number that is returned.
For that particular error, the error number is 1062:
error-messages-server.html
As this is something that requires custom coding, it is not supported, so I can only point you in the right direction.
rick178787
JW, okay I understand. But I'd think this is a rather common problem (preventing duplicates in a database). Is there a more elegant way to trap these that I'm not seeing?
How would WA suggest this be done?
Jimmy Wu
Using the error code that is returned by MySql as I suggested in the previous post would be what I would recommend.
rick178787
Okay, just checking. I'm famous for bulling ahead with the least elegant solution. my last shop was cold fusion/ms sql, so data error trapping was a bit easier/different.
thanks.
Jimmy Wu
No problem. If you run into any additional issues, feel free to open a new thread.
