SQL syntax error
Thread begun 6/17/2010 12:07 pm by mrobben375515 | Last modified 7/09/2010 2:12 pm by Jimmy Wu | 7161 views | 14 replies |
mrobben375515
SQL syntax error
I keep getting this error when I click on any of the product categories on the "Products" drop down menu...
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ANDProductID IN (SELECT ProductID FROM ps3_productcategories AND(CategoryID = 3)' at line 1
and when I'm on a page the accordion menu on the side with the product categories doesn't work...it's probably related to the above error as well.
The url is www.1to1marketing-llc.com
thanks
Jimmy Wu
This may be caused by the ANDProductID not having a space between them. Did you make any modifications to the query that gets the categories?
mrobben375515
Not that I know of, can I upload some files so you can take a look?
Jimmy Wu
Yes, if you upload your Products_Results.php page, I can take a look at it and see if there's an incorrectly coded query.
mrobben375515
here it is...
Jimmy Wu
Try using the version I attached. This will ensure that there is a space between the AND and ProductID.
mrobben375515
posted it and now I get this error
WHERE ProductID IN (SELECT ProductID FROM ps3_productcategories WHERE (CategoryID = 4))
Jimmy Wu
Just wanted to make sure that the query was being written out correctly. Go to line 85 of that page and delete this code:
die($WADbSearch1->whereClause);
Then run through again to see if you get an error.
mrobben375515
got the initial error again...
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ANDProductID IN (SELECT ProductID FROM ps3_productcategories AND(CategoryID = 6)' at line 1
Jimmy Wu
On line 84, that should look like this:
$WADbSearch1->whereClause .= "ProductID IN (SELECT ProductID FROM ps3_productcategories WHERE (CategoryID = ".implode($_GET["ProductCategoryID"]," OR CategoryID = ")."))";
Change it to look like this:
$WADbSearch1->whereClause .= " ProductID IN (SELECT ProductID FROM ps3_productcategories WHERE (CategoryID = ".implode($_GET["ProductCategoryID"]," OR CategoryID = ").")) ";
