Configuration
I've been away from DW for awhile. Seems I remember there is a fix for this template and editable regions business--see message in image--but I can't conjure it. Any help?
Rick
DW CS 5
php
MySql 5
latest DataAssist
Rick
DW CS 5
php
MySql 5
latest DataAssist
This is a very common error when working with templates. So far I have not found any one solid cure all fix, but my reply in post 2 to this thread has a workaround:
showthread.php?t=4509
Okay, I can see the difference now: workflow.
In the past I did the data work on a blank page. When I had all the code pages worked out another employee worked up the design, created a template and applied it to my finished code pages.
I let DA Wizard use the template from the beginning to try to save time. An apparent false economy. Think I'll go back to the old way.
Thanks.
