Can you create menu/list from single table?
Hi, i'm trying to create a menu select list in a form field using a dynamic list from the database. The table has ItemID ItemName ItemShortDescription as fields. The instructions appear to want to create separate tables for the parent and child but I really don't need that.
I got the 12 items to display in the box IF i add a repeating table action around the menu list field, but otherwise nothing displays.
Is there a simpler way to do this? The array behaviors don't seem to work. This is the first time I've tried to use this extension.
All I want to do is list for value ItemName and for Label the Description and have all 12 items list in the menu field.
