state list
Thread begun 6/16/2010 8:43 am by ross360115 | Last modified 6/16/2010 4:39 pm by Eric Mittman | 3821 views | 5 replies |
ross360115
state list
Hi
Is it possible to change the state list on the users_Profile.php page etc, to a text field? If so could you please advise, what and where needs to be altered to avoid any problems down the line (validation errors etc)?
I would not recommend changing it to a text instead of a select list, this will allow for potential problems wit the taxes not working correctly and will mean you will need to do a lot of extra work for validating the input.
ross360115
Thanks for the advice! I am in the UK and intend to ship to the UK, Ireland and mainland Europe. So what set-up with regards to the state and country drop down menu’s, do you think would be best?
In general we do not recommend making edits to the Solution Packs since they are designed, engineered and tested to be working in the state that you download them in. If you need to make these edits you should first backup the pages before making any edits.
I think it would be best to use text inputs instead of the select lists like you mentioned. To do this you can just add a new text field to the form next to the select list, then just make sure to name the new input after the select list. If they have the same name and id the validations should still work properly. The only thing is that you would need to bind the validation value from the bindings tab back to this text field.
ross360115
Thank you, I shall give that a go!
Your welcome, let us know if you have any other questions.
