WA_SHA1Encryption.php not created
Thread begun 6/15/2010 12:51 pm by koerbcm | Last modified 6/16/2010 2:42 pm by Eric Mittman | 2494 views | 5 replies |
koerbcm
I just followed the steps provided to add encryption and after uploading the whole site i get the following error message:
Warning: require_once(../WA_SecurityAssist/WA_SHA1Encryption.php): failed to open stream: No such file or directory in /hsphere/local/home/cdahlgroup/cdahlgroup.com/cdgadmin/index.php on line 5 Fatal error: require_once(): Failed opening required '../WA_SecurityAssist/WA_SHA1Encryption.php' (include_path='.:/hsphere/shared/apache/libexec/php5ext/php/') in /hsphere/local/home/cdahlgroup/cdahlgroup.com/cdgadmin/index.php on line 5
When i look through my site i can not find WA_SHA1Encryption.php anywhere. Did i miss a step in creating this page or what can i do to create it?
koerbcm
Originally Said By: koerbcm
Just to add...i have uploaded everything in the Security Assist folder and when i look the file does not exist on my server or local machine.
koerbcm
found the problem. added the pages to a file higher in the tree then.
Thanks for posting back about your resolution. So the page was just outside of the site root?
koerbcm
Yes. for some reason it put it one level above where it should of been. Dreamweaver doesn't look there so i only found it cause i looked in windows explorer. odd.
If you encounter the problem again or if you have any other questions let us know.
