Database Cache
I added new fields to a database table, but when I go to the DataAssist Wizard it doesn't see the new fields in the database. How do I get it to see these new fields?
The new fields should be added once you've restarted the DataAssist Wizard. Have you double checked that the correct table is being added to? Also try restarting Dreamweaver so that the connections should be refreshed.
