PowerGallery works on one server but not on an othher
Thread began 6/15/2010 7:21 am by michel336265 | Last modified 6/21/2010 11:51 am by Jimmy Wu | 1995 views | 5 replies |
michel336265
I have installed powergallery at two different servers :
On one off the servers powergallery is working great and at the other one nothing happens. The hosting provider off the one which does not work thinks that the problem is the PHP version they use (PHP 5.3.1).
Working version :
index.php?gallery=5&theme=dark
This one will work. On this server PHP version 5.2.13 is installed.
On the other server (other hostingprovider) :
index.php?gallery=1&theme=dark
This one will NOT work. On this server PHP version 5.3.1. is installed.
Can someone please tell me how to solve this problem.
With regards
Michel Post
The Netherlands
Jimmy Wu
I have opened up a backend ticket to look into this issue a little more. To check your backend ticket, log in to your account at www.webassist.com and check your support history.
michel336265
reply
hi,
do you have any idea when there will be an answer?
Jimmy Wu
I don't see a response to the ticket from you. No progress can be made on the issue until you respond on the ticket.
michel336265
Where should I responde?
Jimmy Wu
Originally Said By: Jimmy Wu
Follow the instructions from my previous response to find the ticket that was opened for you.
