Two Forms on same page?
Thread begun 6/14/2010 12:24 pm by james276087 | Last modified 6/18/2010 4:18 pm by james276087 | 4130 views | 17 replies |
james276087
Hello,
I wonder if it is Ok to have Contact Form and Registration Form on same page.
thank you for reading it
Jimmy Wu
Yes, you should be able to add two different forms onto the same page without any issue.
james276087
thanks,
I have Contact Form and tried to add Google Pro Map and having little problem.
Is it ok to add the Google pro map on the same page...
thanks again
Jimmy Wu
Yes, you should be fine adding the map as well. Make sure your cursor isn't in the form when you're adding the map. Are you getting an error message when you insert the map?
james276087
Not getting the error message, but couldn't completed.
On step 5, click on ' include directions' and try to get the code from Dynamic Data but doesn't show ' simple form' only show---simple contact, server variables and WA validate entries......I had this map on few pages but now forgot everything.....getting old
thanks again for your help Jimmy
Jimmy Wu
Can you attach the page that your form is applied to so I can take a look at it? Maybe the form code is being added in a strange way so it isn't being recognized as a form.
james276087
I attached the file and now i'm getting error message and strange worD on the page.
Error message
"This web site needs a different Google Maps API key. A new key can be generated at maps/.
this message pop-up twice and ">/*wagmp*/ " show on my web page.....
WHAT A MESS, JIMMY
THANKS
ps. contactus.php
Jimmy Wu
This just means that the API key that you are using for the map is different from the one that is needed for your domain. If you are testing on localhost, you can use the one we provide you in the help documents. Otherwise, you wll have to generate your own:
signup.html
james276087
thanks Jimmy,
Sorry to asked you two questions, my first question was .....
thanks n i attached the file
Jimmy Wu
I wasn't sure if you had gotten past that question, since you applied a map to the page. Looking at your page, there is only a SimpleContact_NewFromBlank_Default form on the page, so that is why there is no other form bindings when you click on the dynamic data.
