Authorize.net Currency Code
Thread began 6/14/2010 8:22 am by mora398588 | Last modified 6/14/2010 12:14 pm by Jimmy Wu | 1115 views | 1 replies |
mora398588
I understand that the currency code for setting up a remote connection should be set to "USD." I have heard from other merchants that this code has caused some problems in processing transactions. Is there truth in this? If so, is there another code that needs to be considered?
Jimmy Wu
Setting up the currency code as USD shouldn't have any issues. The USD currency code refers to using US Dollars as the currency. If you run into any issues when you implement the payment gateway using this currency code, you should post back and we can help you debug the issue.
