menu issues
Thread began 6/14/2010 4:06 am by i.edwards384429 | Last modified 6/15/2010 1:14 am by i.edwards384429 | 1787 views | 5 replies |
i.edwards384429
menu issues
Hi
at
index.php
The client is complaining that if they select find product-- cookers---belling---elements
then they are unable to mselect sub catagories because the menu structure does not persist.
I have tried this on three PC's on site and four in my workshop and all exhibit this issue.
Any ideas would be helpfull
thanks
Ian
I'm sorry, I don't quite follow what the issue is, can you please provide some more details to clarify the problem?
i.edwards384429
update
Hi Jason
ok difficult to describe but
if you go to
index.php
if your select products and then cookers you see the secondary menu
if you then move accross to the secondary menu you will see the tertiary ( think thats a word) menu
one in three times when you move off the secondary to get to the tertiary the whole menu structure closes.
Hope thats clear
thankks
Ian
i.edwards384429
update
Hi Jason
just phoned a friend ( I do have one) and he has the same issue with the site
cheers
Ian
neilo
Hi Ian,
Hi
In IE the menu disappears as the cursor passes over the 'gap', Firefox seems to handle it OK.
The easiest way to sort it would be to make the level-1 and level-2 ul links 5px wider, so in CSSMenuWriter/cssmw_home/menu.css in the width properties for rules ul#cssmw_home ul.level-1 > li > a and ul#cssmw_home ul.level-2 > li > a (at lines approx 108 and 163), change the width in each from 145px to 150px.
I think that should sort it.
i.edwards384429
update
Hi
thanks, that sorted it, didn't notice it was the gaps that was killing it.
cheers
Ian
