Navigation Links including Root Directory in URL
Thread begun 6/13/2010 5:47 pm by elevy388997 | Last modified 6/14/2010 9:56 am by larry268887 | 3072 views | 4 replies |
elevy388997Beta Tester
Hello,
So this hopefully should be simple. I have looked through other navigation threads and think this is along the lines of their problem. I tried the solutions listed (in the other threads) but had no luck. So maybe this is different.
My root directory is /public_html/websites/ and I have the site set to document relative paths. So when I upload the site the navigation has a URL of: aboutme.php ; when it should be: aboutme.php.
Any ideas?
neilo
Hi elevy,
Check the database that you set up for sculptor, in the wa_settings table for PCMS Remote Root.
If the path contains public_html/ - you could try removing it.
larry268887
Hi
After creating the site with site sculptor did you by any chance modify the menu using menu writer?
What do you mean by check the database...? I never set one up. I used the wizard and a stock template with some color modifications. Where would I look for the file that adds the path?
And I did modify the site with menu sculptor, by clicking on the menu and using the edit menu command.
larry268887
CSS menu writer is not compatible with site sculptor
CSS menu writer is not compatible with Site sculptor. I do know how to correct the problem and if you want to email me at larry@3dphotocharmjewelry.com I can tell what you need to do to get the menu working.
