lowercase upload filename
Thread began 6/13/2010 9:24 am by info399547 | Last modified 6/14/2010 7:19 am by Jason Byrnes | 1003 views | 1 replies |
info399547
This is the 3rd time i'm posting this, i hope that i will finally get an answer!
I need to convert the filename of the uploaded file using UE4 to lowercase.
I have tried to place strtolower in a few spot in the script below but keep getting errors.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../media/documents/images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "2",
'ResizeWidth' => "460",
'ResizeHeight' => "",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "../media/documents/thumbs/",
'ResizeWidth' => "90",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../media/documents/downloads/",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "imageFile", "2", "[NewFileName]_[Increment]", "true", strtolower($WA_UploadResult1_Params));
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "downloadFile", "2", "[NewFileName]_[Increment]", "false", strtolower($WA_UploadResult2_Params));
I would need an answer sooner rather than later, please!!!
Thanks for you help
it looks like Eric gave you the correct answer in the following thread:
showthread.php?t=13515
in the webassist/file_manipulation/helperphp.php file, change line 86:
$attemptedFileName = str_replace($existingFileNameDefault, $baseFileName, $attemptedFileName);
$attemptedFileName = strtolower($attemptedFileName);
