New Database return errors from the index.htm
Thread begun 6/12/2010 9:27 pm by ken317419 | Last modified 6/16/2010 6:28 am by Jason Byrnes | 5971 views | 13 replies |
ken317419
Startup Page you provided returns the following error on almost every script listed>
This was for the script users_Registration_Simple.php
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
No database selected
this is the page I am working from
startup.htm (I already had an index page for the site)
CraigRBeta Tester
the link to the url posted does not work
The "headers already sent" error is usually caused by having white space or text before or after the opening and closing PHP tags (<?php . . . ?>).
it is widely documented on the net.
check this on your page, and on any 'required' or 'includes' pages as to the cause
see the following page for information on the case and solution to the headers already sent error:
148/
ken317419
Web address
I just check the link again startup.htm and it appears to be working.
On the default registration page (from the page you provide) when I click on user registration I get the following errors:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Your help would be appreciated.
the error is reporting a problem in the Connections/localhost.php file around line 13
Look in that file around line 13 for a blank space:
148/
ken317419
Local Host File
Copy of localhost.
# FileName="Connection_php_mysql.htm"
# /home/mysql/beyetran_ur
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "/home/mysql/beyetran_ur";
$username_localhost = "beyetran_admin";
$password_localhost = "uT4pxxV3";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
This is the file. If you would like to look at the site I will gladly give you access permissions and username and password. This site is in development so nothing is secret. Thanks for your help.
neilo
Hiya Ken,
Are you sure of your connection database setting in this line?
I haven't seen the mysql directory path being used before; I would have thought it would be just:
$database_localhost = "beyetran_ur";
ken317419
Changed the database line and issued the registration.php . Got a form with fields plus the following error at the top of the page
ken317419
Registration page did allow the registration even with the errors on the top of the page. Sent the verification email with the verification link. Executed the link and it came to the log on page. the Log on page had the error messages at the top. Entered the email / password
and pressed log on and got a page with the following errors.
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/users_LogIn.php on line 29
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/users_LogIn.php on line 33
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/users_LogIn.php on line 37
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/users_LogIn.php on line 41
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/users_LogIn.php on line 45
Warning: Cannot modify header information - headers already sent by (output started at /home/beyetran/public_html/Connections/localhost.php:13) in /home/beyetran/public_html/WA_SecurityAssist/Helper_PHP.php on line 38
ken317419
Admin Search errors
After registering a user (me) I went the Admin section and logged on. Got the same two errors as before but did see the graph with a user shown. Did a search by email and got the following page See attachment with the errors shown.
Advise ... we are making progress
