Shopping cart not clearing after checkout
Thread begun 6/12/2010 7:05 am by dave403891 | Last modified 6/16/2010 6:54 am by Jason Byrnes | 5472 views | 11 replies |
dave403891
When the checkout process is complete and the emails have all been sent, the next person trying to place an order finds all the products from the previous order still in the shopping cart. It doesn't matter if this is the same customer placing an additional order or someone new visiting the site. There is no site login.
What additional code do I need to add to get the cart to clear? Do I add it to the checkout_success page?
Ideally, the trigger here would be a return to the index page or leaving the site.
I know this is a simple task, but being so new to PHP it is still beyond me. I checked out the previous thread from pmait97856, but it was not clear to me what to do.
Thanks for your help.
add thje following code to the checkout success page after the </html> tag:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params session_get_cookie_params();
setcookie(session_name(), ''time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
dave403891
Jason,
As usual brilliant! I don't know why I thought my situation was so unique. Learning continues
But, I just noticed something else that I can't fathom. When anyone on the checkout page checks the "Same as billing address" checkbox. The shipping address does not populate nor does it appear on the confirm page. What do I have to learn here?
Also, should I start a new thread when I have another issue like this?
try it in Fire Fox after clicking the same As Billing check box, go to Tools -> Error Console to see if there are any javascript errors being logged.
can you post a link to the checkout page?
dave403891
Jason,
Did as you asked and here is the error message
Error: eCart_copyBillingToShipping is not defined
Source File: checkout.php
Line: 1
The link is listed in the error message. Hope this helps solve the puzzle.
your checkout page is missing the following script tag:
<script src="WA_eCart/Scripts/copyShipping.js" type="text/javascript"></script>
it should be just before the closing </head> tag
dave403891
Jason,
Thanks. That worked but instead of the confirm page rendering, I got this message:
Duplicate entry '0' for key 'PRIMARY'
What does it mean and how do I fix it?
the primary key for either the orders table or the order details table is not set to Auto Number.
Double Check that the order and order details table primary columns are both set to Auto number.
dave403891
Everything renders, but I have this warning below the footer on the checkout_success page:
Warning: Cannot modify header information - headers already sent by (output started at /home/davcow9/InnerchoicePublishing.com/checkout_success.php:192) in /home/davcow9/InnerchoicePublishing.com/checkout_success.php on line 273
Line 273 is noted below in the additional code we added to get the cart page to empty:
session_start();
One other thing, the email receipt is not generating as it was before.
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
// This is line 273 );
session_destroy();
change that line to:
@setcookie(session_name(), '', time() - 42000,
