Restoring original presets
I've been experimenting with form builder and have inadvertently edited presets that I'd like to restore. How is that done?
You would want to go to your download center and download the presets. Then you would want to go to the Insert->WebAssist->Preset Manager and import the default presets. You might want to remove the modified presets that you overwrote as well. If you want to keep your presets in the future and also the custom ones you made you should try renaming the custom one when you save it.
No problem. If you run into any additional issues, feel free to open a new thread.
