Menu not working in IE8
Thread begun 6/10/2010 11:21 pm by christian184364 | Last modified 7/08/2010 4:41 pm by Jimmy Wu | 6945 views | 17 replies |
christian184364
A menu I have created works perfectly in all browsers except for Internet Explorer 8, basically the menu is only displaying as linked text with no style or drop downs.
I have read the FAQ and have added <DOCTYPE> tag (see below) as suggested but this makes no difference.
Please help..
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
Jimmy Wu
Please post a link to your page with the menu applied so we can take a look at the page and determine what is causing your issue.
sysop349733
Me too
I am having the same menu problem in IE8. Would you please take a look at mine too? This was created with Site Assist. Please notice the "undefined undefined" at the beginning of the file. I don't know if that is related, but it is odd.
index.html
neilo
DOCTYPE Needed!
Hiya Sysop,
I think your page will be sorted for IE8 once you have proper a DOCTYPE declaration at the top of your html section of your page.
The DOCTYPE lines should look something like:
You will need these at the top of each of your site's html.
Do you have the DOCTYPE declaration lines there already? There may be a problem with them (maybe unclosed tags). If in Doubt add new (or replace existing) lines with the above two.
Firefox/mozilla seems to manage without them, but IE needs to know what's expected of it.
sysop349733
Thanks!
Thank you. That hass resolved the problem. As I mentioned, this page was created using Site Assist Pro. Did I miss a configuration option that would have inserted this or did Site Assist fail to include it?
Jimmy Wu
The page should have been generated with the doctype tag there. If you try running SiteAssist Professional again and this happens again, it is most likely something having to do with some settings set up in your Dreamweaver.
sysop349733
Problem continues
I checked my Dreamweaver (CS4) preferences for "default documents type" and it is set to XHTML 1.0 transitional.
I tried creating another test site with Site Assist Pro wizard (Personal, artist, Cabo Sunset, default, default)
When the wizard asks for "Page Generation," I chose XHTML 1.0 Transitional.
Here are the first few lines of code created for index.html. Note there is no doctype.
undefined
undefined
<head>
<title>Home Page</title>
Jimmy Wu
So you're getting different results when you generate the pages again? If you could take screen shots of the Local info, Remote Info and Testing Server sections in your site definition and send these back, that would be appreciated.
sysop349733
Same results
Not different results, the same results -- as I reported above: No doctype and "undefined undefined" preceding the head tag.
Screenshots attached.
Jimmy Wu
Try setting your testing server access to local/network and set up the information for the testing server to match with your hosted server. Then run through the wizard again to generate the pages.
