store files mapping to viewable files?
Thread begun 6/10/2010 6:57 am by rasputin307444 | Last modified 6/10/2010 11:43 am by Jimmy Wu | 1434 views | 1 replies |
rasputin307444
I just installed PS3, with no problems with SSL or MySQL.
I installed to the primary domain, acting as the common "mall" for three secondary domains, which are "stores".
I realize that I may not be giving enough design info as well as definition of my assumptions, however, I will have all three stores use the same shopping cart and checkout even though they will each have a different store layout/ambiance/design and access their own set of databased products.
Today, Thursday, I will be adding my Super Suite and Subscription extensions to DW CS4.
The admin access is only showing the first store from its admin perspective.
How do I see the PS3 rendition from a web URL perspective (as if I was a customer)?
How would I create other PS3 instantiations for more than 1 store?
Which files will I be opening to tweak the store entrances?
I foolishly am looking for an XHTML file....
Jimmy Wu
Something like this would require quite a bit of modification and is not supported. PowerStore is meant to be used as a single store for a single site, not for 3 different stores that are linked to different sites.
