error using insert record and universal email
Thread begun 6/10/2010 3:23 am by aaron408361 | Last modified 2/16/2011 11:52 am by Jason Byrnes | 3849 views | 8 replies |
aaron408361
hi,
when using insert record and universal email I am getting this error message:
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in C:\Inetpub\wwwroot\Cosmoprint\WA_DataAssist\WA_AppBuilder_PHP.php:11) in C:\Inetpub\wwwroot\Cosmoprint\webassist\database_management\wa_appbuilder_php.php on line 19
any ideas?
you have two require once statements on the page to attach the WA_App Builder_PHP.php file.
one is attaching it from:
Cosmoprint\WADataAssist\WA_App Builder_PHP.php
and the other is attaching it from:
you should remove the second require once statement.
aaron408361
starry sentment
thats the strange thing, I only have it declared once, but I figured it out, WA_AppBuilder_PHP.php is called in the file mail_formatting.php which is included, I commented out the require_once("WA_AppBuilder_PHP.php") in mail_formatting.php and now it is OK.
that's very odd, I have never seen the WA_AppBuilder_PHP file included on the mail_formatting.php file before.
glad to hear you figured it out.
aaron408361
yeah, here is some code from inside mailformatting.php, Ive commented out the require line:
function processEvent($isError) {
if ($this->ToDo == "none") {
return true;
if (sizeof($this->ColumnList) == 0) {
return false;
$LogIncludeDirectory = getcwd();
chdir(dirname(__FILE__));
require("../../Connections/".$this->Connection.".php");
#require_once("../database_management/wa_appbuilder_php.php");
chdir($LogIncludeDirectory);
eval("$"."logConnection = $".$this->Connection.";");
eval("$"."logDatabase = $"."database_".$this->Connection.";");
mysql_select_db($logDatabase, $logConnection);
$insertParams = WA_AB_generateInsertParams($this->ColumnList, $this->TypeList, $this->ValueList, -1);
switch ($this->ToDo) {
Andrew Read
Just ran into this same issue - commented out the same line of code - Is this on the fix list?
Should this not be listed as a "Known Issue"?
Or is there another fix?
this has been logged as a bug in our bug base.
it is not listed as a known issue because we are not able to reproduce the issue, but we will be looking into a fix for it in future update.
Lee Firth
Add me to the list of people having the same issue.
this will be corrected in the Next Update to CSS Form Builder 2.
