insert single record having problems
Thread began 6/09/2010 6:39 pm by JBWebWorks | Last modified 6/18/2010 3:52 pm by Jimmy Wu | 2233 views | 6 replies |
JBWebWorks
Using data assist inserting into data base.
MYSQL 4.1.20
In the form is a textarea and also a hidden field and included in some of the text of these fields is the character, |
It seems that the character | is being received as a field seperator and dividing up the text from the single textarea and putting into several fields in the database.
What can i do to get the insert code to recognize the character | as text?
thanks,
Jim Balthrop
Miguel
Can you give us a bit of more info or the file affected to check out where is the problem?
JBWebWorks
The php code for the insert
// WA Application Builder Insert
if (isset($_POST["submit1"])) // Trigger
$WA_connection = $connauto;
$WA_table = "unclassified";
$WA_sessionName = "unclassified_ad_ID";
$WA_redirectURL = "ucp02.php";
$WA_keepQueryString = true;
$WA_indexField = "ad_ID";
$WA_fieldNamesStr = "client_ID|ad_header|ad_title|ad_price|ad_city_state|ad_description|pic1|pic2|pic3|pic4";
$WA_fieldValuesStr = "".((isset($_POST["hiddenField"]))?$_POST["hiddenField"]:"") ."" . "|" . "".((isset($_POST["Cad03"]))?$_POST["Cad03"]:"") ."" . "|" . "".((isset($_POST["postingtitlediv01"]))?$_POST["postingtitlediv01"]:"") ."" . "|" . "".((isset($_POST["postingtitlediv02"]))?$_POST["postingtitlediv02"]:"") ."" . "|" . "".((isset($_POST["divbox01"]))?$_POST["divbox01"]:"") ."" . "|" . "".((isset($_POST["userdescription"]))?$_POST["userdescription"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["clientFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult2"]["clientFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult3"]["clientFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult4"]["clientFileName"] ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_connauto;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
this field
contains text and the character '|' (this is used as a divider for appearance)
my thinking is that character is a field seperator when used in the php insert code, so when it sees that character in the "Cad03" field, it reads it as a database field seperator.
I could not use the character in the "Cad03" text field and that would solve the problem, but i was wondering how to get the php code to see that character as text only?
Jimmy Wu
You could url encode that text field before storing it in the database. You would also have to decode the data when you're getting it out of the database as well though.
Here is a reference to the url encode:
ref_urlencode.asp
neo314
I think the extension should encode that character before using the character as a separator and decode it in the sql statement. It is a standard keyboard character that should be anticipated as input.
In the meantime, I suggest encoding any input server side as easiest. No other input should be using the bar character, so I add this:
// encode vertical bars
foreach ($_POST as $key => $value) {
$_POST[$key] = str_replace("|", "&#38;#124;",$value);
I am having that problem with HTMLEditor and when I tried to get HTML editor to encode it I lost all the input which came out NaN.
JBWebWorks
Jimmy,
thanks for your help; worked perfectly.
The input field that contained the character '|' many times was on the insert page from a previous page that had a form action taking it to the insert page.
So i used the urlencode this way
<input name="hiddenCad03" id="hiddenCado3" type="hidden" value="<?php echo urlencode((isset($_POST["heading02"]))?$_POST["heading02"]:"") ?>" />
That field was inserted into the database encoded and then when i wanted to pull that information from the database and display it on another page i used a recordset this way
<?php echo urldecode($row_rs_unclassified['ad_header']); ?>
Regards,
Jim Balthrop
Jimmy Wu
Thanks for getting back that you were able to get it working. If you run into any additional issues, feel free to open a new thread.
