Missing Images
Thread begun 6/09/2010 11:37 am by CraigR | Last modified 6/09/2010 10:12 pm by CraigR | 2300 views | 4 replies |
CraigRBeta Tester
Missing Images
I thought it was going well !
I have just created a second gallery on my site, called London.
The images uploaded ok, and I can see them on the manage images page.
When I try to preview them, no images appear, but they do appear for the other (photostudio screenshots) gallery.
photostudio.forthwebsolutions.com/
as well as navigating via the menu, you can preview in the admin section
go to index.php to look at the admin area
user name is test, password banana.
once logged in, within admin, you can navigate to Edit Content-> Gallery Pages.
Useing the 'eye' icon in the table, you can preview the page.
the first one works fine, the second shows no images.
i have tried updating watermarks, but to no effect
the images folder seems to have all of the required images intact.
CraigRBeta Tester
Hmm. - it isn;t straightforward.
I just tested this on my daughters laptop, and no images appear, in either gallery.
when i then add some of the london images to the gallery on my local server, they also appear on the remote host.
i checked and re-uploaded the connections file, and that seems ok.
if no-one has any ideas, i may just bite the bullet and re-install.
CraigRBeta Tester
Fixed
I just realised, i imported the database to the live server, it was the only thing i hadn't checked.
the root path needed to be updated.
panic over !!
neilo
Hi Craig,
I did notice that all the images were being called from impossible urls, and half decided to mention it, but then decided that you were probably doing something brilliant and I would just be exposing my ignorance.
CraigRBeta Tester
You were right !
I am easily overestimated !
