eCart 4.5 - Powerstore
Thread begun 5/29/2009 12:40 pm by Scott Noyes | Last modified 6/05/2009 10:47 am by Ray Borduin | 4305 views | 5 replies |
Scott Noyes
I have recently purchased Powerstore and have been setting it up. One problem I am running into is setting up a connection to my new MYSQL database. the connection works fine if I am setup in a non Powerstore file. what could the problem be.
There must be something different. The powerstore was built with our tools and dreamweaver and the connection is just a standard dreamweaver connection definition. There is no reason why it would work differently than any other.
Do you get an error?
Scott Noyes
it acts like it is connecting. Then comes back with unidentified error has occurred.
Are you able to set up a connection to that database in general? It sounds like it may be a problem with your site definition?
Scott Noyes
Yes I can connect to the new data base no problem my original ecart store files. I even set up a connection for the old database in the new files and it won't connect to that. So it has to be something in the Powerstore files it does not like. Everything connects fine live. It just does not connect with in Dreamweaver.
I think it is a problem with your site definition. Can you set up a connection to another table in that site.
