Deleting site and creating a new one
Thread began 6/09/2010 8:45 am by randyw2394710 | Last modified 6/09/2010 5:17 pm by Jimmy Wu | 994 views | 3 replies |
randyw2394710
I have installed a site using site sculptor. It worked fine. I wanted to try again so I deleted the data base tables which were used, and the folders. reupload the the new folders. How do I install it again. Every time i try to go to the install it automattically takes me to the admin
Jimmy Wu
Did you replace all the folders or just some of them? If you go into the Connections folder, if there is an installed.txt file in there that isn't blank, then the installation wizard will think that the cms was installed already. Make sure that that file isn't there when you navigate to the files.
randyw2394710
hello im unable to delete the text file on server
Jimmy Wu
Why are you unable to delete it on the server?
You can also rename the file and it should have the same effect.
